Electronic boost controller question?
MSP3.5
So, I just bought a SARD Racing Trigger style boost controller. I was wondering where is a good Ignition Wire to splice into? I cant find any wiring diagrams on the MSP. Any info is greatly appreciated. I am electrical wire retarded by the way so if this is a stupid question please be easy
i know someone here knows where to locate the ignition wire in our MSP's? if so i could use some guidance.
Check out the12volt.com They have the diagrams. All you have to do is search.
well that 12volt source didnt seem to help any at all... thanks anyway.
can anyone else assist me in locating a good power wire,ignition wire to splice into inside the car for an electronic boost controller...thanks again for any help.
when i try to splice into the fuse panel inside the car all the positive wires seem to be staying on constant. cause when i plugged in my harness to the boost controller istelf along with my power wire connected, it stays on the whole time even with the key out
You jusst need a power wire? How about the radio or cigarete lighter, those don't have power when the car is off try those.
ok i just ran an individual power/accessory wire, all i need is the ignition wire now... so if yall got some info on that ign. accessory wire lemme know, thanks a lot in advance
