eibach alignment kit
Tommy1005
just wondering if the kit is needed to straighten everything out, or if there is enough room in the stock adjustments to straighten it back out.....I would like to have my camber set closer to 0 deg. so that it will hook a little bit better out of the hole.....thanks for your help.
Tommy
You will not need it. I put Eibach sportlines on my old MSP and when I had it aligned. The guy said it was slightly out of alignment and he put it back to factory spec.
bump for an answer to the same question re the Eibach ProKit. Is there enough adjustment in the stock parts, or do I need an alignment kit?
I have the prokit on my MSP and the shop put it to the right specs. I have even wear on all my tires. The front has -1 degrees of camber and it works awsome.
I put the TEIN S-Techs on a while back, had extremely uneven wear (to add to what was already there). Just got brand new Kuhmos, had it aligned the other day. Drives a decent amount straighter now, I guess we'll see in a few thousand miles how well the alignment was done. The guy at the shop said there was no problem getting it to the specs I gave him and I do not have any sort of camber kit.
