EBC mounting kit
travisto
titanium 04' MSM
I've seen several EBC's out there. My question is...Has anyone tried making use of that little flip down compartment below the deck for an EBC or anything else? Also isn't there already a hole through the firewall behind there for the stereo to run off the battery? (uhm) Any info would be appreciated. (kiss)
I know it's only my TT, but when I ever get around to buying a GReddy EBC, it'll be going right under mt TT...And there are holes running through the firewall, you just gotta look for them. I know one is on the drivers side, about half way down.
Well mine isn't below the deck, but I have mine under the ashtray in that little pocket. Here's a pic.
As for the hole in the firewall. The only one I've seen is under the driver side dash right above the pedals to the left. Thats where I run my boost hoses and my EBC harness. Hope that helps. :D
REPly to REPLY
Nice pic, its nice to see creativity in the world...keep up the good work! (kiss) I was considering doing a similar set up.....and will now that I see it's possible! (outie)
REPLY to REPLY
Thanks for the info. I found the whole! (2thumbs) Usually I only have that problem in the dark... (naughty)
I was thinking the same thing, the Greddy type II EBC and TT, I was thinking possibly a gauge on the right but I dont think there would be enough room. So I might do side by side and keep the door. I think it would really add to the sleeper look. Also, it keeps thieves away since they wouldnt think anything of it.
I think you might have to trim out part of the inside area. I don't think they will fit side by side or one on top of the other. I'm looking at basically removing the pocket, and only leaving the door to conceal them. The final setup I want will be to have the TT and EBC on the left side, and a single gauge, like an EGT or something on the right. All hidden behind the flap:)
