dyno results
beh just go buy a $5 carb spring, slap her on the actuator and do a 8psi dyno run. i bet you will be happy. you dont need an ems until you are boosting over 10psi. of course they will give you better numbers even at the same boost level but you would be fine boosting 8.
I am dynoing this Friday. I am expecting low 200's
CAI
downpipe back exhaust
no cats
FMIC
Intake manifold
TB spacer
J-spec cam
boost on 9psi
Can't wait to see the numbers
dirtysouth_msp said:
What the **** is that bulls*** below some of our post counts? Someone needs to get a life...(321fu)
I think it's your browser, i get the same problem at home but not at work, it's probably the title that goes with your rep point score.(dunno)
at 6psi you should not expect much. i think the numbers are right. try 8psi
You said it was on a mustang dyno correct. Then on a typical dynojet you'd put down about 178 whp. 155 x 1.15 = 178. Mustang dyno's typically read about 15% lower than a dynojet. Ask any dyno owner/operator that actually understands them. For your mods I think you are doing just fine.
This is my Dyno video. This might help you a bit. It was done on a Dyno Jet dyno. The only exhaust work I have is a 2.5" Midpipe with 1 High-Flow Cat to a stock exhaust pipe then a TopSpeed Canister Muffler. I know I can hit 200 if I replace the muffler but money is tight right now.
Click here to see Video
doubt the muffler is corking the system. i have a 2.5"dp and midpipe to 3 inch catback with stock muffler, seems fine. id say the extra noise isnt worth the 2hp
im gonna get the unichip and i think my stock bypass valve went so im gonna get a new one any suggestions i know apexi makes a setup and forge has a bypass and bov, i already have a greddy type-rs venting to the atmosphere near the throttle body so should i recirculate the charge pipe valve? also i have a t3/t4 turbo does anyone make a manifold o fit the mazdaspeed the only ones ive seen were OBX...
So I hit 235hp/ 237 lb/ft tq
Not to bad. The guys at Top Speed were expecting sub 200's I just smiled.
