SenorCorwin said:no to many legal problems so he decided not to go through with it.
I did my own little dyno run on the street with the supermap and the richest I saw was 11.2 and as lean as 12.5 on the top end. Stock boost, fmic, cai, stock exhaust. After tweaking the maps I was running even more rich, 10.5 down low and 12 flat through the upper power band. Since I don't have a way to log boost pressure, I'm just guessing where I need to make adjustments. I'll be getting the MAP sensor soon so I can start doing things the right way.^tyrant^ said:orange, can you post the map that came on yours? im running the supermap, and i dynoed the car the other day 185whp, but it was running so rich it was of the scale below 10. just want to compare
