Driving Lights / Fog Lights
Mazda5 Sport
Ok, I have an 07 Sport and one of the lower lights (driving lights / fog lights) went out. Looking at replacements I see this is an h11 bulb. I'm considering moving to LED lights maybe even in yellow. I did find a cool set that will switch between yellow and white as well and they cost about the same as a phillips xTream bulb. Anyone done this yet? Any thoughts?
If you use them for their intended purpose (to illuminate the lane borders in low visibility) or even just at night beause they look cool, then you'll want to stick with an H11 bulb as anything else will change the beam pattern to the point where you will lose the cutoff and create glare for yourself and oncoming drivers.
In the slim chance you use them like high beams when there is no oncoming traffic or off-road, then disregard my reply and put whatever you want in.
