Drivetrain play
Put the part in after work today and went for a quick drive. Upshift, downshift, rock solid again. I am so not gonna miss that thumping.
Inspected mine one last weekend... Found that one rubber is shut. Going for the replacement for the whole bracket.
Thanks, MidLifeCrisis, for pointing that out.
STOCK Parts and how much they cost.......
The transmission mount is 122.21 Rear Motor mount is 91.90 and the side mount ( Ridiculously priced) at 273.69. I can't seem to find the Rear Arm though for that rear Motor Mount....
My car suddenly feels like the rear motor mount is missing or something. When I shift or take my foot off the gas, it feels like the engine is rotating several degrees and I usually hear and feel a thump from under the car. It has been raining here so I got under it only briefly last night, by jacking up and supporting one side of the car. The rear mount looks fine.
Where do I start looking for loose pieces? What is the most likely next culprit to check?
Thanks in advance.
i'm experiencing the same thing, i had a minor issue with my gen1 SU RMM and they're replacing it, so once I get the new RMM in I hope for this to be resolved. in case that doesn't fix it does any1 have pix of the locations of other places to check and what types of things i'd be seeing if there was an issue
