Drivers' Side Power Window Control Panel Problem
Khagghen
2007 Mazda CX-9 Grand Touring
I have a 2007 Mazda CX 9 GT. This afternoon, when I tried to roll down the windows, the power window controls on the driver side door panel would not respond. The controls had been working fine the entire day, but I rolled them up run the AC and then later noticed that the panel control would not operate the windows thereafter.
The red lights that are usually on in the panel are all dark, as are the lights that are associated with the power side mirrors. However, the power side mirror still operates normally, only the power window controls for all four windows are non-operational. The passenger side power window control is still functional and the red lights are on. I thought that it might be a power window fuse problem, but was wondering why the passenger side power window is still operational if that was the case. Any and all advice would be greatly appreciated.
Different fuses for left/right windows.
Check the fuse.
If not the fuse, it is likely the window regulator.
Hi Ceric,
Thank you so much for the quick response, I really appreciate it!
Looking over the owners manual, I only found 1 fuse associated with the power windows (that is, not 2 separate fuses for the windows), it is fuse number 32 in the glove compartment' I couldn't find another fuse for the power windows.
Could you provide me with some guidance on which fuses control both left and right power windows?
Thanks - Dennis
