Driveline shudder in first gear
glimontague
2012 Mazda5
I purchased a 2012 in the beginning of the year. I've noticed a shuddering between 5 to 20 mph, presumably in first gear.
This is a cpo car so it's under warranty. Just curious if this is normal or if I should take it to the dealer.
Sent from my SCH-I545 using Tapatalk
Too many possibilities. Failing trans solenoid, torque converter, map sensor, maf sensor, vacuum leak, failed O2 sensor just the name a few. Let me know what you find out..
Check your right and left motor mounts first. My car was all wierd with knocking, shuddering and whining/whirring and it all came down to block/body contact.
Latest posts
