does the front end have a sway bar?
I might be mixing up parts here, but I was wondering if the front end had some type of sway bar like the red racing beat one in the back? I know there's a brace under the hood over the battery terminal, I was just wondering what the suspension should look like in the front. Just got my car back and I want to see if the job was done right.
Yes, you can see if you peek down through your engine bay. It's right near the axle. You can see it even better from underneath the car. It's red in color, just like the rear swaybar.
What you're looking at (the silver bar mounted to the top of your strut towers) is your front strut brace. In that case, you only have a strut brace in the front, you have to go aftermarket if you want a rear strut brace.
What did you get done? How would you know if the job was done right if you don't know what the front suspension looks like?
well........
I ended up swerving into a high curb, really bending the a-frame and joints to the front passenger side wheel. I never looked under my car after the accident so I don't remember what it looked like. I didn't notice a red racing beat bar in the front when I looked under my car today so I was wondering if one was actually supposed to be there.
yeah, one is supposed to be there...
you should be able to see the outer parts of the sway bar through the wheels..
If you still can't find it... follow the endlinks connected to the strut to the sway bar..
Go underneath your car and look up the wheel well, you should see the red bar, the paint looks pretty much like the one on the back.
