Do I flash?
So most of u say "yes flash." hmm...like two months ago it was the complete opposite, but oh well.
Question: after flashing, do u notice ur boost kicking at all? my 2nd gear has BAD hesitation.
I just got mine flashed today...thanx guys for the advice! the difference is night and day! im glad i did it..im thinkin eventually i will run 8psi max...but for right now..im enjoying the stock msp with flash!
this brings up a good point. if you're flashed, be careful about upping the boost.
DiscreetSpeed said:
like marbles hittin is what it sounds like....
When I reset my ECU a couple days ago, I let the car Idle for about 5 min (while checking tire pressure) and then I went out. I drove it easy for about 1 min and then I went WOT. It was here when I heard this marbles hitting / pinging. I am 100% stock (no injen, no dp, no K&N drop in) and I heard this pinging. It only did it 1 time, but I agree w/ ARunto, our cars can ping. (I'm running 93 octane since day 1 as well)
Ideas? The only thing I can think of was the ECU was relearning fuel maps and it didn't give a good a/f causing this ping.
-Fnny
it can be anything...thats the thing our engine is so noisey...it could from the exhaust manifold to the turbo...i wouldnt worry about it.
