OK, so I haven't seen much on the forum about it yet from the posts I've read, so I figured I would start one. If I missed it, please hook me up with a link.
I've read some things about our stock injectors not being anywhere near maxed out and the cam pump being a limitation, while I am not disputing the cam pump (aka look at laloosh, nice work btw man!), I am not so sure about the injector duty cycle headroom being as high (seem claims of 600hp) as some are stating.
With direct injection, it seems the injection event has to occur at a very precise point when the piston is at the peak (or near that) of its compression stroke. Now, with a port injection engine, you have a significantly bigger window available to inject fuel, thus there is room to increase the PW of the injector as opposed to the amount of flow at the stock PWs (within reason).
Does anybody have any more technical information with regards to direct injection? What about the diesel guys? What do they do?
