disable automatic volume control
rptjr
'05 Mazda3s
This is what I'm noticing.
The only time the system sounds like it has any balls is when the automatic volume control is set the the maximum (3). In better terms let me describe it this way. It appears to me that the increase in AVC is not directly proportionate to the increase in volume. As I have read in another post somoeone said as you pick up speed the volume, if set on 14, eventually sounds like its on 17. But I dont agree with that exclusively, yes its louder but the quality of the sounds is poor if the AVC is not set to the max. Its like the AVC is turning up the amp to give deeper bass and better highs. Heres what I would like to do but dont know if its possible. I want to disable the AVC and still have the volume and sound quality react as if it were on the max AVC setting of 3.
Any advice?
