For the past two or three days, I've noticed that my car would dip to 500 rpms when coasting to neutral. It doesn't matter what the rpm is (blow off or not). I'm currently running a dual setup (stock bpv, greddy type s with three threads exposed). Never had this problem before until recently.
Yesterday, I changed my spark plugs and did a seafoam injector cleaning and noticed white smoke coming from the exhaust manifold area...This never happened to me before.
Possible problems I can think of at this time is a leaky vacuum hose, cracked manifold, or bad gasket between turbo and s pipe (recently had my mechanic install the GHL dp).
Has anyone else encounter this problem before? any solutions?
