PR54LIFE said:I want another one
tonkabui said:the cf one is not resistent to scraping at all. it also cracks easily. stick to urethane if you don't want cracks to appear along with the scrapes.
Mazda5owner said:urethane is way better...just make sure you drill it good. The 3m tape will work but one accident it will end up on the freeway. If you don't plan to remove itafter you install it, just drill the sucker in and use a lock nut.
