Hi, I've had this car for 6 years now so I might as well make a build thread lol. I got the car as a graduation present from high school so I had it with me for the last few months of high school. I owned it all throughout college and now I've been using it to commute to work. I usually take the car through 9, 130 and metcaf but I also do everything with it from going to SF to driving to and from work.
I'll need to work on tracking down everything I've done to the car but this is what I can remember off the top of my head
Engine bay/Drive-train
AWR motor mounts 95
Goodridge clutch line
cc delete
washer fluid delete
VTCS delete
Excedy OEM spec clutch
resurfaced flywheel
TWM Performance short shifter with bushings
MP3 Flashed ECU
MP3 intake manifold
stock airbox and snorkel but with snorkel resonator delete, replaced with air ducting to bottom hole on 90 degree bend
Mishimoto radiator
Mishimoto fan shroud
2.5 inch exhaust after second cat
Suspension handling/Wheels
Ksport Kontrol Gen 2 coilovers (retired)
Megan Racing coilovers (current)
Racing Beat front and rear sway bars
Enkei RFP1 F1 Silver 17X7.5 +48
Bridgestone Potenza Pole Positions
Hawk HPS front pads
Steel braided brake lines (soon)
ARP extended studs (front)
4mm spacers (front)
Muteki open lug nuts black
Just Accessorize (sssh)
DGM front urithane lip
C West canards
MS3 short antenna
35% tint
Torque solutions 3inch extension
FEED shift knob
AutoEXE oil cap
TWM Performance alcantara shift boot
OEM Black flip up cup holder
Kenwood Deck and all four speakers
LED interior lights
6000K DDM tuning HIDS
Sound Deadening on Front doors
Corbeau FX1 side mounted driver seat
Hid my ballast under the headlights
That's all for now, I have a lot of other plans for the car and I'll get some more shots in a bit.
AWR motor mounts 95
cc delete
washer fluid delete
VTCS delete
resurfaced flywheel
MP3 Flashed ECU
MP3 intake manifold
Mishimoto radiator
Hawk HPS front pads
4mm spacers (front)
C West canards
MS3 short antenna
35% tint
FEED shift knob
AutoEXE oil cap
LED interior lights
