WOW so much damn stupidity over a muffler and a resonator.............
First off resonator and a muffler do the same thing...... they both make the exhaust a little more quiet. A resonator does this with less backpressure than a standard typical "muffler".
Yes they make mufflers that have a straight through design and others that are baffled (flowmaster for example). Typically a car has one resonator and one muffler, the resonator helps kill the sound effect more than anything(droning the cabin), mufflers take it a bit further and slows things down a bit to help make it quiet.
Now i'm pretty sure there's a thread around here that shows NO PERFORMANCE GAIN from removing the exhaust. if thats true then replacing the resonaotors with striaght pipe did nothing but make the car MORE AUDIABLE........meaning LOUDER!!.
IMO the car has 2 resonators , 2 cats and 1 (ONE) Mufflers that is of straight through design.
This is one of those the glas is half full VS half empty... Either way, the only thing you changed was the sound, thats it. If there was any performance increase, YOUR BUTT CERTAINLY DIDN'T FEEL IT. exhaust changes are usually miniscule in performance unles a full tuned exhaust was installed and tuning was done to compensate.
For me a DP and a cat delete wpould be worht the money to change out, but anything else is a waste, UNLESSS you want more sound.
