DDM Tuning Apexcone Raptor HID Kit - $30 plus shipping
ok, take the bulbs... plug them into the ballast on the only end where you can make all of the connections off of the ballast work.
this will leave 2 connections for your HID bulb and one for the stock wiring harness on the car on the other end... plug the appropriate connections into their respective sockets.
this should be laid out in the included instructions.
Mhm I got the main idea down. I just don't get how I'm supposed to hook up the red and the black wires by the bulb up. Isn't it supposed to come with a connector?
headlight harness plugs into HID harness. HID harness plugs into HID ballast, HID ballast plugs back into HID Harness, HID harness plugs into HID bulb...
easy pleasey.
I don't have an hid harness though I only have 2 wires
If you scroll up you can see one of them in justanothermp5's picture the one with the bulb
That's the black one, there's a red one right next to it that looks almost identical
yeah, I understand... but without seeing a little more of what is going on, its kinda hard to just talk you through your issue...
They plug in to where your factory bulb plugged in, just figure out which is positive and negative. If you get it wrong it won't fire up so it's not hard to figure out.
DDM is ******* ridiculous.
Customer service sucks. They never pick up the phone.
They sent me the wrong bulbs, I ordered more than 2 weeks ago, and they still are giving me a hard time about exchanging them. **** DDM.
Couldnt have put it better myself. First try, I had the wires in the wrong spot. Switched them, I was golden.
Huh...
They were very good to me, they swapped my bad bulbs out under warranty, no problems.
They sent me H1 bulbs, and now they are giving me a hard time as I'm trying to exchange them. They're trying to make me pay for a new set of bulbs.
I'd never run a 3000K kit in the US... WAY too much attn.
lol i actually got them cuz i thought they were more low key then the 10000K
as soon as i got the 10000's i saw like 20 civics with them and it made me hate them, its like every crappy car has them, so i figured i would go with a color i havent seen on ANY car
so i got the 3000K's, plus they are a bit brighter
