Dashhawk for AF ratios?
AllLostThings
2007 Mazdaspeed 3
I recently decided to get something to monitor my AF ratios. Would a dashhawk do the trick or should I plan to get that and an actual gauge? Thanks.
yes the Dashhawk will give you the true A/F ratio, and it will give you the desired A/F ratio, which is what the ECU is wanting the car to be. The sensors are already on the car, use what you have...
for the most part monitor, AF ratio, boost {(until i install the prosport ventpod gauge), boost temp, and gas level (because the dashhawk is blocking the gas gauge)
Sweet. I alkready have a boost gauge from Prosport but I guess I'll et get the Dashhawk to monitor everything else. Thanks.
does the cobb ap monitor the afr accurately? cause during wot I'm reading 11.7 my highest. I never gone more than that on wot 4 gear. is that good?
That sounds about right..... even maybe a little lean still, but that all depends on the rpms your basing this on...
