hey yall i now have a kenwood ddx8017 but i ran into a problem, it has the "safety" feature that wont let you play a dvd while in motion, does any1 know of a way around the "safety" features
i have the pioneer and all you have to do is ground out the e-brake wire. i dont know about the kenwood but i am sure their is some simple trick like that. did you install the hu your self? if so did you have to run a wire to the e-brake?
rob
no i didnt install it myself and it only does it whenever i take of the e-brake, i.e. if the car is in drive and the e-brake is activated then it will work just fine
so by saying grounding it out you do mean to disconnect the wire that goes to the e-brake and just attach it to its own ground (bolt) and it wont make it difference other than the "safety" feature deactiviation
that is what i did. read out the wire it is hooked to first. with the e-brake applied and your key on acc is that wire a ground, or does it have 12 volts? then disengage the e-brake and see what happens. i found that with my e-brake on the wire became a ground (same ur's will be if they hooked it to the same wire) so all i did was grounded out the wire from the dvd deck and mine screen always works!!
btw here in WA it is a 1200 dollar fine for having a movie playing in view of the driver!
