I thought you were going to double up to make it flush with the frame rails. Weren't you almost scraping the exhaust?
Battery + terminals was right around $70 IIRC. Reliable? So long as I keep it on a trickle charger (I have to do that currently, my battery's on the way out, which is why I finally got a light-weight one) between events, it'll be fine.
thats not bad then i know i hear stories of people buying super lightweight batteries and them not being very reliable
Make sure your trickle charger has an AGM setting. The $5 trickle charger from HF is not AGM compatible.
An AGM setting will allow the charger to "cycle-down" and not overcharge/explode the battery (AGM type). At least that is from my understanding.
You could just install a kill-switch. Which is really easy to do and you can mount it to the roll cage like we did with the Spec.
Yep, that's what I've gothttps://www.amazon.com/dp/ (commissions earned)
highly highly recommend this. I have had a couple people buy these per my recommendation (you see them all the time on the DIY auto tv shows) and they love them.
I agree. I don't have a $5 trickle charger, but do have a battery tender (see below). It's already brought the miata battery back to life a few times (oops...) and works great. But yeah, with the lightweight battery I'll have to be pretty diligent about that.
RE Kill switch: It's definitely a planned future upgrade, but it's one more thing to spend money on right now. At this point it's not a "need" item, so I'll get to that probably when I find one on a stupid sale from Summit or Pegasus or any of the other numerous race-part shops that send me newsletters lol
Yep, that's what I've got![]()
Why did I think the kill-switches were in the $100+ range? Cool deal![]()
I'll sell you one for $99.
See, there is a reason why you keep me around.
No matter what I'm going to have 15s as transport / rain tires (I can't even get out of my garage on the 13s...), so it's basically a non-issue at this point.
WTF? You're going to trailer your car to events, then still have to swap wheels on-site? UR d00in it rong.
Problem is that with the 13's the car is so low that I can't even get it out of the garage, much less up onto a flat-bed trailer. With an enclosed, super-low deck trailer this wouldn't be a problem.
You should definitely go that direction then.
Maybe get a new house too, to fix that garage issue?
