Cylinder 1 Misfire
LakeSpeed6
2006 MazdaSpeed6
Started the car up and engine was running rough, engine code came up saying cylinder 1 misfire. Cylinder 1 wasn't firing at all. Started the car again to move it so I could check spark plugs and engine ran fine. Drove it around town with no issues. Started it next day and ran good for about 10 min before cylinder 1 stopped working again for about 30 sec before working again. Changed the spark plug and swapped coil packs but still cylinder 1 stops running at random times for elongated times, not just intermittent.
Any thoughts of other things to check. Thanks
That sounds like you may have a bad connection where your wires run too. Start from Cylinder 1 coil pack and trace it to where the wires stop at. I'm not sure what its called it basicly took place of a distributor but thats where it stops check around that to see if there is a loose connection if thats not it then take it to a mechanic or if you know any friends have them check it out.
