Cx9 Remapped! Top speed 212kmh!
GrandSavrify
CX9
Hello all Mazda owners, I got my Mazda CX9 remapped yesterday, the limiter has been removed and the car is able to go 212kmh, it's still going but there was car in front. after remapping the engine fault code appear so I still have to wait for my tuner to get things done. When the car is on high speed, the brake disc is a nightmare I can tell, I changed the crooked brake disc but still the same. Maybe I should go for brembo brake?
Get better pads, torque the lugs nuts with a torque wrench to the proper torque spec, and have the rotor runout checked and have the rotors resurfaced to flat if they're outside the factory spec.
All numbers needed are in the service manual.
after the tune, and not driving at 212km/h, have you noticed much of an improvement in fuel consumption with normal driving?
Mazda service centre told me that it was a manufacturer defect, they recommend me to change a new branded rotor such as Brembo instead. Will keep you guys updated if I got a new set of brake.
Cheers (nana)
sorry I'm with the rest of the folks here...WHY? I'm all for power, my last car had a 332ci motor making 460HP but the CX-9 is not a high speed vehicle
