Or this (well hopefully not, this looks like a bigger job to do)
Summary
Some customers may complain about a poor acceleration and rough idling or the CHECK ENGINE light ON with DTC P0301:00, P0302:00, P0303:00, P0304:00.NOTE: Only turbo engines are applicable; non-turbo engines are NOT applicable. In most cases, DTCs P030X stores, but sometimes not. Sometimes the CHECK ENGINE light does not recognize this engine concern. This is caused by the variable valve in the exhaust manifold seizing and causing the exhaust port to become hot and the exhaust valve seat to wear unevenly, resulting in compression leakage. To eliminate this concern, the design of the exhaust manifold has been modified.
