I know this is a common issue. I’ve replaced the motor once already due to water. This time is different. I replaced the motor and it still doesn’t work. I swapped the relays under the hood to rule that out, and no change. When the car is first turned on, the motor spins for about a half of a second and then stops. Rear blower works fine. Unless there are more relays I’m not aware of, I’m at a loss as to what other component failure is driving this issue.
