Dalton said:
I 'm told, that to get most out of that type of performancemeters,
you should get Gtech Pro SS or Gtech Pro RR if you prefer datalogging
http://www.gtechpro.com/ (cool)
The G-Tech claims to be accurate with zero to sixty since it measures the start with a momentum change. The Dashhawk gets the information from the onboard computer which detects the wheels spinning and also gets a message that 60.2 MPH is reached. Assuming that you have not put shorter tires on and your speedo is off by a ton, it does not get any more accurate.
I used to have a GTech and found it not to be very accurate. You need to on be a perfectly flat surface (no bumps anywhere or it throws off the G meter since it measures X, Y and Z), the item cannot be moved once it is calibrated (permanent mount suggested), and it is triggered by sustained acceleration (if you soft launch the car, the you can get some rolling time without the clock running). For example, if you calibarate on a flat surface and find a nice open spot that is slightly donwhill, you will accelerate with .52 and lose a little, say .02G so your run is actually slower. The 60 MPH is determined by math not by measurement. So, this much acceleration measured in G's for this long with this time and, voila, it can calculate speed. And, as an FYI, the accuracy they quote is the ability for the device to sense a 0 to 1 G instantaneous load within .01 seconds. Depending on calibrations, I found it was accurate within .5 seconds on a quarter mile.
Regarding mileage measurements. One item I have not tried, and it makes sense now, is to try and pull metric measurements from the ECU instead of US. Maybe those are sent out. I will report back, but if Dalton's is working on a US spec car, then it should be the same since the DashHawk and Scanguage read the same computer outputs (OBDII outputs).
shadow1 said:
One thing to consider. If you are doing back to back 0-60 runs and the weather is warm, you will probably heat soak the TMIC and see slower and slower times. Did you observe this?
Yes, I did consider this. All the 6.8 to 7.0 runs were heatsoaked runs during the day. The fastest 0-60 was a cold run. The car was started, brought to the acceleration area at 60 mph, stopped, then launched right away. It was also a cool night (daylight heats the pavement to about 10C over measured air temps - this is the air your car breathes), high barometric pressure (air density), no wind, and the road was cool (thanks to the evening weather). All that put together, and you get a good run. And, the Acura RDX with almost the exact same HP, torque specs and vehicle weight somehow does 6.5 0-60MPH consistently. Looks like they have their tuning down a lot better than Mazda.
