CX-7 Engine will not run
arnie37
cx7 2008 2.3litre turbo
Hi there, I'm currently doing a fuel injector replacement on a Mazda CX-7 2008 model (due to one of the injectors being faulty), I'm currently having issues with engine as it will not run, it only winds over and fires once but does not idle or rev up when applying throttle, I can hear a buzzing noise from throttle body whilst ignition is on, I have ran a diagnostic scan and there are no codes present, prior to repair, car was displaying code cylinder 2 miss-fire.
I've checked for vacuum leaks and there are none present. The new injectors have a different part number on them to the original ones and are a different colour.
Any help or advice is much appreciated, cheers.
