CX-5 Service mode stuck
Rear passenger wheel.stuck service mode doesnt come off ..all other wheels R rotating though.
Spindle rotates for 20 seconds but doesn't unlock brakes;(((
Help please
Thank you
Phil
UPDATE UPDATE
Update: Right rear caliper was dead. I replaced it $230 OEM, could have waited 8 days for a aftermarket one $130 but needed the car right away.
Help please
Thank you
Phil
Update...
Tried to manually release pressure from rear of faulty caliper but ...nothing. Brake pads are compressing the rotor ...doesnt rotate a bit .
Ill pinch the brake hose and might open bleeder a bit tonight to see if I can release caliper....TBC
Upvote 0
Are you working with a Service Manual? Attaching relevant section on parking brake, I think it would be useful if you don't have it already. There is a section called ELECTRIC PARKING BRAKE FORCED RELEASE PROCEDURE that may be relevant.
  • PARKING BRAKES.pdf
Upvote 0
I already found video on forced parking release procedure but thank you
Upvote 0
Make sure not to spin the piston. When you force release the caliper, after few rotation you will feel the resistance, STOP right there. Do not forcefully spin it.
Upvote 0
Help please
Thank you
Phil
Upvote 0
Latest posts
