- RDX Aspec Adv.
What did you get from it?
Nothing, it's just the best I could find. Or maybe something...back end is an LSD apparently?
Brakes make it rotate?Open differential, I haven't found any evidence otherwise. You saw traction control at work braking the wheel that gets air.
"With the CX-5, what happens if one of the front wheels goes in the air / loses traction with the ground?"
I'm very curious about that as well. I searched high and low, but from the drawings in service manual, it looks like that the rear axle gets power through the transfer case (two gears really) only from the front right hand drive shaft. It's not "symmetrical", as with Subaru AWD setup.
I'd imagine that if the wheel gets in the air it gets brake from ABS/TSC system, and the power goes to another wheel on the axle. But then it becomes peculiar if the RIGHT front wheel loses traction. It gets the brake, the left wheel gets traction, OK, fine. But what if the left wheel has no traction either? The power can not be sent to the rear because the front RIGHT axle is under the stability system control already...
Beats me...
That is how the open diff on my G35x works. The TCS uses ABS to simulate a limited slip diff.
I appreciate your feedback. Being in WA i'm sure you've gone through your share of snow tires. What other brands have you used?
That was a good video. Nice to see the AWD performing as I'd expect.
Was that second song Russia's version of Judas Priest? (nana) (guitar)
