Hi
My CX-5 seems to getting a lower than expected fuel economy. The agents claim that it should do less than 9L/100Km and mine shows 12.3L/100Km or more. Today the agents said the A/F sensor may be blocked internally so to run at high RPM to clean it. Tried that but it doesn't seems to work. This evening I drove the car (city limits) and recorded some of the PIDs using FORScan. The O2S11 and MAF readings seems wrong. Do any of you have knowledge/seen these PID values and advice me what is wrong. If I know if any setting is wrong I can start shouting at the agents demanding a proper troubleshoot. Any help is appreciated.
I have attached a zipped CVS of FORScan readings.
thank you.
thank you.
