- CX-5 2017 GT AWD
Here is how my cockpit looks like now with the dashcam and Radar Detector Hardwired and Phone holder using the Spigen Kuel.
@finch204
Yes stuck the dashcam mount to the housing of the the RADAR/CAM. I used a double sided gorilla mount. I can still remove the dashcam easily cause it is only the mount attached to the housing.
@finch204
Clean rig man. How did you power the radar detector? Thanks.
I used mirror tap this time to power the RD. The dashcam is just the regular straight cord connected to the lighter socket. The cord is run through the roof liner down the a pillar
@Fruitwolf it is connected to the rear view mirror. Here are the pics. Hope this helps.
make sure you zip tie it after so it is securely connected.
Same here. However I paid dealer to do it because I'm afraid I might accidentally trigger the airbag inside the A pillar.I have dashcam too. I routed the wires through A-pillar trim.
