darrylintoronto
Not sure where to start...
since the first winter I had my Protege 5, it has made a crunching, creaking noise when I drive my car on COLD day over speed bumps or up slight inclines.
All summer long, it has been fine, but now that it is getting cold, it has started again,, It seems the colder the weather, the louder the noise and the smaller bump required to make the nasty noise. It can be so loud that you can here me going over speed bumps from 300 feet away.
I have had the sway bar bushings under the front bottom of the car replaced twice. This seems to stop the noise. It was last done in February of 2009 and it will need to done again soon.
Both times the bushings have been replaced was covered under warranty even though the car was out of warranty. I had complained every year about this noise for the 5 years it was under warranty and had written documentation of this fact. Each time I was told that this noise was normal and nothing to worry about.
I contacted Mazda Canada and they finally offered to look into the problem. Gyro Mazda fixed it the first time, and Dufferin Mazda fixed it last year.
I spoke to Dufferin Mazda and they do not guarantee warranty work and thus I will have to pay this year to replace those bushings. At least if I pay, it will have a 1 year warranty.
My question, why does this keep happening. Is somthing bent that is making the bushings wear out? Should I go back to Mazda Canada and try to get it fixed again under good will warranty?
I bought the car as a demo model from Dufferin Mazda. It had 15,000 km on it. When I bought it, I got the full 5 year warranty as a new car. Do you think perhaps that the previous driver could have hit a speed bump way to fast and bent something under the car, thus causing the bushings to rub and wear faster than normal.
I really hate the noise it makes. It sounds bad and it makes me feel as if I am driving a car that is about to fall apart.
sorry for the long ramble...
any related assistance is much appreciated.
