Creak/groan liftgate
Mazda 2016 CX-5
Have developed a annoying creak/groan from right side of liftgate when opening/closing. Any suggestions as to where to lube and what type of lube to use ?
With the hatch fully open, I wipe the chrome shaft of the lift supports very clean, and then place a drop of silicone oil, or even engine oil on the chrome shaft and o-ring where it meets the black nitrogen lift body. Then lift and lower the hatch several times fully in order to distribute the lubrication, and verify noise is gone.
(rockon)
Ditto^^^, except I use vasolene petroleum jelly on the shaft.
