Crank gasket leaking like crazy!
2001 Mazda Protege MP3
So i'm hoping its just the gasket at least lol. How hard is it to change this? I can get to it pretty easily from underneath but I dont know exactly what all I would need to do. Just pull off the pulley and put it on? Any help would be great!
Are you talking about the front crankshaft seal? If so, you've got to remove the crankshaft pulley, then the lower cover, then the crankshaft gear for the timing belt, then remove the seal.
