CP-E StandBack2 - AFR/Timing and tuning for NA Mazda3
Akaveli
I Alwayz Haz Ava Hottiez
Contributor
{2002 Mazda Protege DX}[2004 Acura RSX Type S]
Just wanted to spread the word around. CP-E is in the process of developing a SB specifically for the n/a 3. I'm going to try and summarize all the information on whats been going on. Since my vehicle is one of the cars they are testing this standback on and some of the results are from my car i'm going to post what has been done so far in this thread.
Per Dimaorlov from CPE,
The CP-E standback2 piggyback computer has been available for the turbo Mazdaspeed models for some time.
I am now trying to get it to run on the regular 3.
This piggyback will serve as a fuel controller and a tool for timing control.. There is of course real time tuning, graphs, data logging and etc.
This would be of great benefit to the 3 owners with both NA engines and aftermarket turbos
I've just started working on it and need lots of testing, refinement and adaptation to work with the non turbo Mazda3 - a few weeks for sure before anythings shows- but I will do my best to keep things updated.
This is just a heads up on the project.. and I would like to see if there is any interest in this type of setup and for what applications.
For turbo applications
AFR, Timing, standalone boost control, option for bigger MAP sensor, ProFuel controller(meth, injectors), BlackBox option..
The boost controller: What would be needed is a AEM 3.5BAR MAP sensor (for which the SB has provisions for), and a wastegate solenoid thats closed by default (again for which the SB was designed for - solenoids are made by a good amount of manufacturers) Note: 3.5BAR might be abit overkill for after market turbo application of like 8-10psi (3.5BAR - about 30psi). Perhaps a 2.5BAR might be better in which case we would need to change the firmware on the SB to interpret it correctly.
With those two things - the Sb would be able to very effectively control boost. Our boost control method relies on a very sophisticated PID (Proportional-Integral-Derivative) feedback control loop, which will adjust the wastegate automatically until the desired boost pressure is achieved. In other words, you can type your desired boost pressure into the software, and the controller will hold that boost pressure from your boost threshold to redline. Furthermore the SB has the capability to to VTA. You can tune your maps so that the injectors shut off between shifts, which nearly eliminates all the popping and backfiring associated with venting your blow off valve to the atmosphere.
Both the air/fuel and timing tables are based on huge 30x30 tables for enhanced tuning resolution. Fueling changes can be accomplished by scaling the MAF sensor output voltage (for the NA).
The engine controller allows on-the-fly adjustments of boost pressure, ignition timing, and fuel delivery all in real time. The SB can also datalog just about every engine sensor for up to 40 minutes (depending on the selected sample rate of either 5, 10, or 20Hz).
I went to CPE to get the SB installed as well as get my car dyno tuned on their mustang dyno. The results...
3.29.2009
Per Dimaorlov from CP-E
The dashed line is what AK came in with on his car minus the standback.
The solid line is with a good tune down low to midrange, and conservative up top - we were getting tired and didnt want to push the car as we have been working with it half of the day and putting lots of stress on it and the dyno. I will tune it further as AK drives around on it for a while to see about stability.
We gained alot of Torque down low and gained a good amount of Horsepower through the powerband.
I havent driven the car afterwards, so Ill let AK do the talking about how it feels.
The tune I recieved added and pulled fuel until 5700 as well as added timing. As a result, we gained alot of Torque down low and gained a good amount of Horsepower throughout the powerband.
Since then my car has been running smooth with the tune and everything else looks good. I'll keep ya'll posted on any new developments and when the SB will be released.
Also any questions ya'll might have, I'll try to answer and if I can't answer I will get an answer for you. :)
i am keeping tabs on the other thread over on the other m3f and there is deffinatly some interesting stuff going on.
Yea, I should have started this thread awhile back. lol I'm going to update this thread as much as possible and post my experience with it so far.
Update from Dimaorlov...
Solid lines are AFTER TUNING.. dotted is BEFORE TUNING>.
Zoomba has Intake Headers and Exhaust..
good day today!!.. im happy with results.. 20wtq gains.. and 10-13whp gains across the board.. the graphs say all!!!
From Zoomba,
Sorry my post got cut short cause my class break was over. On a 40min lunchbreak now.
Anyway, for those wondering, my flow mods were an Injen cold air intake, VTCS removal, Vibrant header, and a Vibrant Catback exhaust (hiflow cat).
Driving impressions so far are very good. You'll definitely feel the extra power throughout the band, especially at WOT. Most notable is how smooth the power delivery is, it's not herky jerky at all.
Remember it's not about peak numbers it's about the differences and how it increases not just the peak but all the way across the power band, starting from the begining. This gives power that you can actually use.
Also dimitri was being conservative with the tune in the higher RPM.
As I was trying to say before I'm waiting on getting a replacement tire for my flat, before I really push in higher gears, lol.
Hopefully I'll get it before the weekend and luckily that's when it will stop raining.
Thanks Dimitri for all the work ya did bud.
Thanks for the great work Akaveli!
That power band looks really nice.
Mz3's are starting to see some really nice NA tuning solutions.
From Dimaorlov,
The Standback2 for NA Mazda3 is officially up on the website and available for ordering!!!
Do note this is a Pre-order.. you may place your order and you will not be charged until it ships..
From the website: http://www.cp-e.com/2157.html
Mazda3 StandbackTM Engine Controller
Dont leave wasted horsepower on the table!
cp-e is ready to share the success of the Standback Engine Management with the Mazda3 community! Now there is no excuse for driving a poorly tuned, but otherwise beautifully modified Mazda3. The Standback can adjust the engine's air/fuel and ignition advance, as well as control electronically regulated turbochargers.
The Standback comes bundled with custom software. The air/fuel and timing tables are based on big 30x30 grids for enhanced tuning resolution. Fueling changes are accomplished by scaling the outgoing MAF voltage. Ignition advance can be increased or decreased by increments as small as 0.1, and both parameters may be adjusted in real-time, and react immediately.
The boost control method relies on a very sophisticated PID (Proportional-Integral- Derivative) feedback control loop, which will adjust the wastegate solenoid position automatically until the desired boost pressure is achieved. In other words, you can type your desired boost pressure into the Standback software, and the controller will hold that boost pressure from your boost threshold to redline.*
The user has the ability to store up to two maps in the Standback controller, and they can be toggled in real-time using the included map toggle switch. The Standback can also datalog or simply display vital engine functions (laptop computer required), which can be invaluable for troubleshooting or for optimizing tunes on the track.
Testing has shown 15whp increases across the powerband with nothing more than air/fuel and timing optimization.
as far as top end this really has nothing to do with the ecu as far as changing top speed ? how much different is this from a split second?
sorry for being a newb :)(uhm)
This standback does not adjust your top speed.
Well the difference bwt the two is alot. Split Second is a fully programmable air fuel controller with wideband datalogging. So far we have a few members using this EMS but no one can produce dyno results showing whether or not any gains have been made.
As for the CPE SB, it can control AFR, Timing, standalone boost control, option for bigger MAP sensor, ProFuel controller(meth, injectors), BlackBox option and other features. The SB can also datalog just about every engine sensor for up to 40 minutes. Also cpe provided dyno results to prove the standback works.
How difficult is the install?
And does it come with any basic maps for those of us who dont know how to tune
From what dimitri meantion the installation is difficult. And there will be basic maps that will come with the standback.
ok well thanks for the info, I wanna get this done for my car really bad, just need to find a place that can do it I guess
