CP-E Standback
You have to take off the whole panel(go at the bottom with a flat head), and pop the switch place holders out from the back, they are held in with tabs and if you pull forward they will break, if you don't hold them down, to push them through.
ehh too much work.
Can you set up launch control with the cpe standback?
Rev limiter and clutch position sensor seem like they could be part of the cpe standback. That is all controled by the stock ecu right?
If anyone knows of another way to get launch control in the ms3 please help me out :)
the cp-e is a standback, but i suppose its possible. i just don't know if it can adjust the rev limiter..it can't adjust speed limiter
oop, i was thinking standback and wrote standalone :(
/stands in corner
Yeah, the harness is so you don't have to do that, making dealer trips easy, so they don't know you've messed with the ECU, and makes installation easy.
They have the plugs (as the MS6 PNP is out)
They are still reverse engineering the MS3 factory ECM plugs I believe.
coolbeans, soon enough it'll be pnp for ms3. I wish there's three settings u can switch on the fly. 1 high 1 mid and 1 for idiots like valet and service attendants who dont take care of driving ur car cause it's not theirs. hehehe, but i guess two is enough, you can always assign ur primary and secondary using a computer right? You can have as many maps as u'd like right?
not if you have a computer you can save as many as you want like he stated. you can only have 2 on the unit itself but as many on the computer to flash when ever its hooked up.
So any one have dynos with the CPE...? Stock? CAI? And full modded beast (CAI, TBE, etc...)?
Who is CPE made by...? I'm only familiar with Xede since thats the one I'm going with...
