DistantTea
- Mazdaspeed... of DOOM!
I was rolling down my windows and noticed that if I rolled both my driver and passenger sides down it slowed down.. I assume from power drain.
Ok maybe they're on the same circuit and its a governed feed. But then if you turn the stereo way up and have the lights on at idle the lights dim... ok another coincidence... but when the cooling fan kicks in it has the same effect.
Could we be seeing some sort of electrical limitation on the car? I'm at 900 miles and don't have a single problem, except a damn rock chip already, but I see these power fades. I've noticed its easier to bog the engine when the cooling fan is on, or you have the AC blower on.
Didn't WRX's have a problem like this that could be resolved by a better grounding system? How'd they do that? I'd like to test it.
