New Release CorkSport Stainless Steel Brake Line Kit
n3rdgen@CS
CorkSport Rep
๐—ก๐—ฒ๐˜„ ๐—ฃ๐—ฟ๐—ผ๐—ฑ๐˜‚๐—ฐ๐˜ ๐—ฅ๐—ฒ๐—น๐—ฒ๐—ฎ๐˜€๐—ฒ!
Stainless Steel Braided Brake Lines
Thank you to everyone that requested we offer these via our new product idea submission form: https://corksport.com/product-ideas.html
โ€ข Mazda 3 2004 - 2013
โ€ข Mazda 3 2014 - 2018
โ€ข Mazda 3 2019+
โ€ข Mazdaspeed 3 2007 - 2013
โ€ข Mazdaspeed 6 2006 - 2007
https://bit.ly/3Yv7mgg
The OEM rubber brake lines often degrade over time with cracking and softening. Replace those with CorkSportโ€™s stainless steel braided brake lines to improve pedal feel and braking response! Front and Rear kits are available so you can do all four corners or match the rears to your front CorkSport Big Brake Kit.
The CorkSport Stainless Steel Brake Lines feature a three-layer design. This 3-layer design combines the capabilities of each layer to create a brake line that is durable and performance-oriented.
โ€ขThe innermost layer is a seamless PTFE tube that is responsible for containing the brake fluid in the brake line.
โ€ขThe middle layer is a stainless steel braid that surrounds the PTFE liner and creates the strength of the brake line.
โ€ขThe outer layer is a PVC coating that shields the stainless steel braid from the elements or wearing on surrounding components.
๐—™๐—ฟ๐—ฒ๐—ฒ ๐—ฆ๐—ต๐—ถ๐—ฝ๐—ฝ๐—ถ๐—ป๐—ด ๐—ถ๐—ป ๐˜๐—ต๐—ฒ ๐—Ÿ๐—ผ๐˜„๐—ฒ๐—ฟ ๐Ÿฐ๐Ÿด ๐—ฆ๐˜๐—ฎ๐˜๐—ฒ๐˜€ ๐—ณ๐—ผ๐—ฟ ๐—ฎ ๐—ฌ๐—ฒ๐—ฎ๐—ฟ ๐˜„๐—ถ๐˜๐—ต ๐Ÿณ๐˜๐—ต ๐—š๐—ฒ๐—ฎ๐—ฟ
