Need4Speed3
- 2008 Mazdaspeed3
Yesterday I installed the CorkSport Power Series racepipe on my 2008 MS3. The install was a PITA (mostly because of the limited working area under the car and my lack of experience). I had to use ramps to access the stock midpipe and crossmembers since my jack and stands were prohibiting me from doing so. Anyways, I finally installed the racepipe and noticed that I left the spacer off of the downpipe.
Here's a picture of the donut gasket attached to the stock downpipe.
According to the installation manual the spacer should be attached to the stock downpipe before the donut gasket. Somehow I completely missed this instruction. After pulling off the racepipe again I tried to remove the donut gasket from the stock downpipe with a flat head screwdriver but it was just not happening. For fear of damaging the gasket I decided that I would just re-connect everything without the spacer. Tightened up everything and the started the car. Listened for exhaust leaks but I didn't detect any issues. I'm not even sure how to detect an exhaust leak. I wasn't able to immediately drive the car since it raining heavily but I did test it this morning and it seemed to pull quite nicely. I haven't noticed any decrease in performance but the increase is not readily noticeable either. Still haven't gone WOT since it was still raining.
How can I tell if there is an exhaust leak? Will it cause any problems if I don't use the spacer?
