Corksport FMIC
even though the box is a pretty cool setup, it is still pretty restrictive. remember a cone filter will always flow more than a panel filter.
This statement is FALSE.
To figure out which will flow more there are 2 factors. 1) filter media flow 2) FILTER AREA.
Cone often have more are due to their shape, but this Corksport filter seems pretty large.
I don't know the sizes but you'd have to measure and calculate to see which will flow better.(assuming the filter media flows the same)
Also the guy who said A good IC will make up for sucking hotter air is WRONG.
The temp rise from the intake through the turbo is EXPONENTIAL, it is not linear.
So you want a cooler everything, the IC will NOT make up for sucking hot air.
