Corksport exhaust question
mxjosh82
03.5 MAZDASPEED Protege
Does the cork sport full 80mm exhaust have an O2 bung to place a wideband? I cant seem to find anything in the description.
the bung is on the cast iron J pipe, which the new exhaust system will not replace.
edit: actually, looking at pictures, I'm only pretty sure about this. you should phone them up. CS has pretty good CS.
Their exhaust is only J-pipe back so you'll still have the bung on your J-pipe for the wideband. There will be a bung post-cat for your secondary O2 sensor as well.
They do however sell a down pipe which is pretty much the only existing option now and it does have an O2 bung for a wideband. You will gain much more performance and response from the down pipe than you will from an exhaust. Ideally, you'd do both.
Keep in mind, their exhaust also has no flex section and you lose the swivel flange of the stock midpipe, so you are required to install front and rear motor mounts inserts.
Alright thanks for the info! I was curious why they asked if you wanted motor mounts while buying the exhaust. I'm still on the fence about doing this and an SSAFC or upgrading to a speed 6....just not sure if I want a payment..F@#@
