Corksport Exhaust 02 Sensor problem!!
rdemattio
2008 Mazda 3 I Sport
Hello, i just installed the corksport Power series exhaust and I do not have the 02 sensor to place into the 02 sensor hole. I was wondering what bolt you guys use to plug the hole? Thanks! Ryan
Any advice? I need a o2 sensor bung plug, but I do not know where to buy one!! Any help is appreciated!
I did some googling and found that an 17x1.5mm oil drain plug would work, So I went at bought one from autozone and bingo =]
Sorry for the extremely late reply, but yes there was no 02 sensor whatsover, my old exhaust came right off with no sensor. Then I bolted the corksport one on and had to plug the hole.
So where is your rear O2 sensor? It's required or you will constantly get P0420 codes.
I have no idea, im assuming its on the manifold somewhere? I guess I can look on my next oil change
You have the primary upstream on the manifold and there is a secondary downstream after one of the catalytic converters.
