- 2010 Mazda5 GT
The original coolant overflow tank has finally developed some cracks after 13 years. I'm planning to replace it with a Dorman unit in the coming days. Upon quick glance last night, it looks like the tank is secured by sliding it on a vertical bracket that's bolted to the frame. And there's a hose at the bottom of the tank that leads to the radiator I'm assuming. So when I go to replace the tank, will pulling off the bottom hose cause coolant to leak everywhere, or is there just a small residual amount left in the hose? Obviously I will do this when the car is cool.
Just trying to anticipate if I should have a container to catch a bunch of coolant or if a towel will suffice. Any other tips on replacing it? Seems straightforward but I wanted to make sure
