Convertible headliner
maybe, depends on how it holds up to the sun cause we all know that you use the boot cover every time you put the top down ;)
Wouldn't want the new liner to get discolored and then it will look just as crappy as if it wasn't there in the first place. And I doubt it will reduce noise a whole lot, unless it's half-inch thick foam.
Yes I use the boot cover every time.
