Nefarious21
Here I am with another problem with my car haha
Ok so a while back I posted about my car not boosting and I fixed it with a non cracked exhaust manifold, but then I had another problem which was bogging like crazy (weak acceleration) and eating gas up like crazy, so I replaced the spark plugs with ngk's gapped to .032 and it ran like a beast until it warmed up. Then the bogging and misfiring came back again, but this time only when under boost. So I checked for vacuum leaks and found nothing, boost gauge reads from 20-25 inHG so vacuum seems fine either way.
http://www.mazdas247.com/forum/show...power-not-sure-please-help&highlight=hot+cold
I found this thread but no one ever figured anything out.
So I went out and did some testing, I noticed that when I hit around 5k rpm I would get a sudden surge of power so I decided to manually open up the valves on the passenger side of the intake manifold (don't remember what they are called) and hold them open with zip ties and BAM drives pretty darn normal! It still bogs a bit, but from all the reading I have been doing (over a week straight 4 hours a day) this is normal with this car. Non flashed ecu by the way.
My question is has anybody who has removed the valves or is running any other intake without them experienced bogging when warm? Also do you guys have any input on what is going on? Maybe the valves aren't opening when they are suppose to or one is stuck closed? Or should I be looking for something else and this was just a bandage to the problem?
No mods other than open down pipe (been to lazy to put everything back together), boost gauge, and a narrow band (I did not put this in the car haha)
Thanks guys, maybe we can help the guys from the other post too.
