Hi Tom,
The 500 lb is from the SCCA:
From the Tech Bulletin in the SCCA's May Fastrack:
2. #4607 (CRB) SSC B-Spec rules and specs
Effective upon publication, add a new subsection 9.1.7.E.34 as follows:
“For each of the following cars in SSC, Ford Fiesta 4 door (2010-11), Honda Fit 5 door (2009-2011), Nissan Versa 4-5 door
(2010-2011), Mazda2 4 door (2010-2011) and Toyota Yaris 2-4 door (2010-2011), the following apply:
Interiors may be removed, including seats, seat brackets, carpet, carpet padding, OEM seat belts, interior trim and
headliners. OEM radio and air conditioner may be removed. Heaters and all duct work must remain, except duct work that
goes under seats.
Maximum 2.5 degrees negative chamber on front and rear; MacPherson strut suspension may decamber wheels by the use
of eccentric bushings at control arm pivot points, by the use of eccentric bushings at the strut-to-spindle, and/or by use of
slotted adjusters at the top of the strut mounting plate. If upper strut slotted plates are used, they shall be located on existing
chassis structure, utilizing the OEM bolt holes and may not serve as reinforcement for that structure. On other forms of
suspension, camber adjustment may be achieved by the use of shims and/or eccentric bushings.
Ride Height: Minimum ride height is five (5) inches, to be measured without driver at the lowest point of the rocker panels,
but not to include welded seams or fasteners.
Suspension: Any OEM or aftermarket non-adjustable shock absorber intended for the specific make, model and year car is
permitted. The shock absorber must be installed in the stock mounting location. Remote reservoir shocks are not permitted.
Any springs up to a maximum spring rate of 500 pounds may be used. The spring must be installed in the stock location.
Threaded shock bodies or adjusters may be used.”
In regards to the springs themselves: If you go to the Corksport site and look at the photos of the coilovers, the Bilstein coilover springs look more like OEM type "pig tail" springs where some of the coils are wound to a different diameter. So I'm not sure if springs can be swapped for others like the Swifts.
The H&R coilover springs look more like conventional coilover springs with a constant diameter HOWEVER that may be a representative photo as those struts don't look like they'd go on a M2 to me.
Maybe Derrick could elaborate? Derrick HELP!
John
