Camber doesn't have much effect on pull, unless it's off drastically. Check your tire pressures?
camber is the main thing that causes a pull. the more angled a tire is the vehicle is gunna pull which ever way ther tire is angled. maybe you mean caster, caster is what helps your steering wheel return to neutral and a car will pull to high caster (the angle forward or back from the imaginary plum line dropped from the upper bj or in this case upper strut mount). Go to a REAL alignment shop and have the take care of it, prolly an extra benjamin depending on labor rate. At my shop it would have been 97.50 in labor pplus the 59.95 for the 4 wheel alignment.
