You'll love the RSB. Makes a world of difference. I suggest you set it to the stiffest setting because I have mine at the softer setting and the car still pushes too much for my tastes but YMMV.
forget the springs. that rsb will take you 30 minutes. put that s*** in there!
also, to install it, it's not like you have to mess with the springs or any other pieces of the suspension (yeah yeah...endlinks...obv)
I just installed my RSB the other day, its really easy like mentioned maybe 30min install time. Make sure you tighten the endlink nuts before the swaybar nuts, gave myself a headache doing that. In combination with the eibach springs its really sweet, you'll like it.
If you believe COBB and Hotchkis, then the COBB RSB at the stiffest setting is the same as the Hotchkis at "less stiff", which is what I'm running now and love.
