Clutch Slave Cylinder.....
Mazda 2 TS 1.3 True Red 5door Hatch
Any body had any issues with the clutch slave cylinder ?
Think the seals have gone in mine, clutch pedal soft and loose 3/4 travel then the last bit idsemgages the clutch ( just about ) had to crash the box and double clutch to get gears to get home, bled it but still the same.....
Getting a new slave cylinder tomorrow.....
Shaun......
Peel the dust boot on the slave cylinder back and check for leaks. Should be pretty obvious.
You can also look under the dash at the back side of the clutch master to check for leaks there too.
yea was the seals on the slave cylinder.... pattern one fitted....
Shaun....
My clutch has been feeling funny the last fews weeks, might've found the culprit. Thanks Cosh
Latest posts
