clunk in the shifter
Auzzie_Mp3
Contributor
Vivid Yellow Mp3
Alright i dont know if anyone else gets this, But when i start up the car and then i put it into first, right when it gets into gear like a loud Clunk noise from under the car happens...have no idea what it could be, someone mentioned to me it could be my syncros? dont know though
yeah sometimes it happens to me too, or if im at a stop light and put it in first, ill hear it. i dont know what it is.
its the heat shield maybe? Is yours the stock shifter or an aftermarket short shifter? After installing a shortshifter, you're supposed to push the heat shield up (against chasis) so that the shifter will not hit the heat shield. I don't know if the stock mp3 shifter will do that too, but worth a try.
jack the car up and just push the heat shield directely up towards the sky. Or you can have a friend change gears while you're looking under and see what's actually happening.
sweet! will do...thanks!
I hear a clunk when shifting into reverse sometimes but not into 1st.......I have an ES though so this post might be worthless (shrug)
eh, kinda sounds like you aren't perfectly in gear, and its "clunking" in... it happens all the time.
it happens off and on, it will go in smoothly one time and then *shift...BAM LOUD CLUNK* its scary but nothing seems like its going bad or anything and its still driving so i think its ok for now
theres a back mount on the shifter assembly. its right above the heatshield. my clunk (similar to yours) was that that rubbre mount broke. so i just rigged it to stay up there.
